Husky Haulers - Hottest setup ever
Sweet!! and I like that flat platform on top ... Looks like steel bars around the bike with curved corners for that custom look .. White rims with some sort of ground-grips on back and you could always slide the bike backwards as needed for more traction as needed .. That ride will carry you many off-road places with only head-clearance as an issue ...
I'm a distance runner up at best to that rig but do have 4-wheel drive on mine :0) ...
Thats my 08 WR250 on the drivers side ... Not vintage but that frame and engine have been around quite a while ....
I was looking into one of those a few years ago. They're available here, or were, not sure if it's still the case. After doing some research found they wouldn't be ideal for any highway speeds & having right hand drive was a bit of a downer. But they do look cool & factory lift kit's were available.
Really like those trucks. I buy them for work and put the lift kits on them and bigger atv tires.
I also put electric dump cylinders on them.
Got to get a little use to shifting stick with your left hand.
Pulls my Husky fine.... when I don't want to be in my truck
