Husky Junk rims
Sometimes, what's clear in 'my' head... is not so clear to others! Yes, the rims sold by huskyjunk.com... does anybody have experience with these? Good, bad, ??? Thx.
used chucks rims in black a couple of years back on a 1973 cr250 rebuild. Other than the spoke pattern difference to the acront rim they worked a treat and the price is good to. hope this helps giley.
vintage husqvarna,s have an odd spoke pattern. 3 spokes face backwards and two forwards. when i gave the husky junk rims to my wheel builder explained this and the modern rims have the normal two crossing over.
Yes. This is one of two issues I've been trying to sort through, with not quite as much help as I'd like from the various sellers. I'd ask: "Does this rim keep the original "Husky Odd" pattern," and the response would be a one-liner along the line of "It will work on your bike." Well, thank you, but how is that helpful? It will work... with stock pattern, or with a non-stock but more traditional pattern? Which, of course, could affect whether I use a set of stock length Husky spokes (off the shelf Buchanan or Vintage Husky) or have to go searching around for other lengths.
Do you ever feel like you're TRYING to give people money but they won't help you do it?
The other is spoke nipple size. These rims are listed as having .277" holes for the spoke nipples. While I'm very happy that this info is provided, Buchanan sells Husky sets with either .281" or .250" nipples. Answers were similar, "It fits your bike." Buchanan does mention that the spokes are for the original Husky Odd pattern, though. But when I called, I was transferred 3 times before anybody knew what I was asking about.
Using .250 nipples sounded very "incorrect" at first, but it only leaves roughly .013" per side around the body of the nipple, with PLENTY of overlap around the head. I'll probably go that way.
