AltRider LLC
So we have had our TR 650 for about 6 months now and that is a lot of time to tear the bike apart and really tinker with it. One of the first things we noticed was a couple of easy improvements that could be made to the voltage regulator and the surrounding mess of wires exposed. So we thought we could share the step by step process we took to cleaning the whole thing up. Let us know if you like this and you end up copying the process on your own bike.
Factory Look: There isn’t much wrong with the factory location, setup, and look of the voltage regulator and guard, but we just didn’t like it. We thought it was a little messy with the wiring and that that our guard would provide much better protection in the long run.
What you need for this little project:
Simply remove the OEM plastic voltage regulator guard and (2) screws using a Torx driver. Remove the two OEM Torx screws holding the voltage regulator in place and following the instructions provided with your AltRider voltage regulator guard, install with the include Torx screws to fill in the old holes formerly used by the OEM guard.
Step 2: Unclip and remove oem wire mounts attached to OEM bracket
Using a flat head screw driver and a pair of pliers simple remove the wire connection mounts from the OEM bracket. Start by using the screw driver to engage the release of the closest wire connection and slid it off of the mount. Then use the pliers to pinch the next mount and pull it away from the bracket. Next twist the first wire mount with the pliers so you can also pull it away from the bracket.
- AltRider Voltage Regulator Guard (made in USA)
- Electrical Tape (black)
- Zip ties (black
