Husqvarna TE 510 rattling sound from engine
Husky Guy
Bike have 3000miles. It's loud rattling noise from head. I opened it and there was nothing. No piece of metals in oil. Cam chain tensioner is on fifth. Where it can come? Have no ideas anymore.
Bike is 2009, but it is with carburettor and exhaust come right side so I think it is some "last year model" when it sold from Husky seller. Right year would be 2007..
Could be lots of things. I would check valve clearance, check auto decomp mechanism. If all good I would pull the head and have a look. Maybe head gasket leak causing pinging, valve broken, broken piston/rings (causing slap).
Could be running lean and pinging.....
Pull spark plug and have a look inside with a flash light.
Thank you for advice. I checked valve clearance it was ok. I check those other things on next week. If i have to change piston, is it good to hone cylinder or is there some "hardcoat" (don't know right word)?
Cylinders are plated not steel. You can't do anything with them if they are damaged except re-plate or sleeve it.
