Husqvarna TE250 sprag clutch replacement
steadyaway
Just sharing this in case this helps anyone as I could n't find any info and the service manual was sparse on info.
Background:-
My 2003 TE250 was failing to start and sounding like the crankshaft was n't being turned so I took the RH crank case cover off
and tried starting. I could then see the sprag clutch was just freewheeling when it should have been driving the crankshaft.
When I tried pulling it off after removing the retaining nut it was stuck and could n't lever it off so I located a suitable bearing puller
off ebay which fitted like it was designed for the job (US PRO THIN 2 JAW BEARING PULLER B5123).
I then fitted a new sprag clutch which needed a pair of circlip pliers to retract the retaining rings so it would fit in the bore. This then needs pushing all the way so the retaining ring sits in the groove at the bottom.
Bike now starts.
Mockup of setup in picture
