ok recently finished rebuilding a air cooled wr430 engine its on its last oversize 74.5, new bore, new piston, new bearings and seals throughout, carby clean as a whistle.runs great until hot and then starts with a hangin idle.
the rpm stays hangin for about ten seconds then drops down to normal.
mods done:
standard muffler shortened by 150mm.
head ported and matched to gaskets and cases.
74.5mm wossner piston.
thought it may have been a air leak but this did not show up on the leak test i did also checked all the seals at 20psi with soapy water and picked up a tiny leak at manifold that has been fixed but thats it she is air tight.
i have manged to stop the hangin idle by jetting it out increasing the size of the pilot to 60 ,main is 450,
so any ideas could it be non carby related, or maybe the carb iitself i know the chrome on the slide is worn away on one side.
i installed a decomp valve to the head but this again checked out fine, all my other bikes run a small pilot and work great.
the 430 starts easily hot or cold just cannot believe it would require such a large pilot, oh and plug looks good no fouling.
mods done:
