I’m afraid that I’m not familiar with the early models but I don’t see why it wouldn’t. I drilled/tapped the end of the slave cylinder 6mmx1 to allow it to “float “ a bit. The price is cheap enough for someone to experiment with.Would this same cable set-up fit a 70's engine?
Isn’t there a short and long version of the arm? And yes, a shorter arm would give additional travel for clutch release.With the hydraulic system you could shorten the lever at the case and get a shorter pull.
You realise the piston diameters at either end do actually change the leverage ratio ?
huskyJames, I recommend it. Very straightforward and easy mod. The short arm addressed the clutch dragging issue. No issues with mine so far. I’m well satisfied with it.Darrel I have the same bike I am setting up and fine tuning right now. After running the shorter arm would you still recommend doing this? saw the last post was a month old so maybe ya have a little more time on it now.
