I need help on this guys. diffrent triple clamps. tc450 09
SMR511Hoon
Well i have a husky TC450 09 now, and just found out the stranded 50mm marzocchi fork leak alot (seen lot of other forums on them leaking..) I've only replaced mine once but they are leaking again 3 weeks later, no cracks, chips, corrosion, scratches..
SO.
I have been thinking of doing the Triple clamp and forks from the husky TC450 2010 model with the 48mm kayaba forks. All i want to know. all of the 2010 kayaba fork & triple clamp will bolt straight up because they are the same frame?
Yes they will. I would try skf seals in the forks, they seem to do a good job of stopping leaks. Fork seals would be easy to try and cheap as well, I have seen other that had good luck stopping leaky forks with skf seals.
Ok Thanks i will try them next time i replace the seals.
