ID Help Frame ML19539 missing engine ID
eddie
Picked up two Husky's last weekend a nice 1978 CR250 and a parts bike that I can not identify. The frame is ML19539 so it could be a 1977 CR250 or WR250 or a 1977 OR360 or a 390CR. The engine plate is missing; is there another way to tell what the engine is?
Without taking the head off if you compare the size of the cylinder of the 250 to the parts bike cylinder, if the cylinder on parts bike is smaller than the 250 it would be a 125 or maybe a 175. If the cylinder is bigger than the 250 it could be a 360 or 390. At that point you would need to remove the head to measure bore. 390 has around 83mm bore, 360 a few mm smaller
