Ignition Questions
hilz129
Does anyone know the timing settings for a 1979 250 WR and a 1979 390OR? I have a dial indicator and need the mm's from TDC
I think you need more advance with lower octane fuel to avoid engine knock caused by preignition, or something like that.
LHill
LHill
Wrong just the opposite. Later George
390 OR=2.19mm. set it at 2.00 mm for todays gas.
250 WR=2.43mm. set at 2.20mm. Later George
I've got a really nice metric dial gauge that will give you .01mm resolution, but unless your motor is brand spanking new, there's no way you can repeatedly get down to the 100th of a millimeter. Just round those numbers and hope that you can get to the nearest 10th of a mm. If you're within + 0.1, then you're doing pretty good. My 500XC factory spec is 2.8mm, and the following year they changed it to 2.2mm. Probably 'cause it will start a lot easier vs. the more advanced timing, but that's just a guess. I don't recall if gas octane changed much between '83 and '84.
as I recall my 85 manual was 2.2 and the reason was wear as the advanced timing was creating havoc in the engines
if you have high octane fuel available and want a thrill you need to try it once, once you get it lit it's like a bullet
but everything comes at a cost, wear and kicking danger, but 2.8 is fun
