Important (?) Correction paint code
Larsa
Guys,
I think there is a typo on the red paint code in the technical reference section.
At least my fuel tank came out green from the shop using code BMW #247, I think the mugello red should be BMW #274.
What can I say, I defined the color as mugello red, have 4 full size picture on exactly how the masking and white strip shall be but then I, THIS TIME ONLY, had to leave in a hurry for other buissness without confirming on the color chart the correct color, so it is definetily my bad all the way.
Sometimes you just have to laugh about things like this. Worse things can happen :)
..By the way, I found this piece, anyone able to educate me on the whereabouts, I did not find it in the engine assembly manual or spare parts catalogue
Shift Drum Arm, spring loaded mounts on centercase with flathead shoulder bolt between clutch and kickstart shaft
Jimspac,
hmm..honestly, I am unable to get where this is going, could you please clarify, I can't fit it.
And I do feel like an newbie idiot asking because it is probably obvious
http://www.yourhusky.com/files/82-husky-parts.pdf
If it belongs in your engine, the roll is spring loaded to hold the shift drum in position when a gear is selected. The roll is dropped in between the pins to keep the shift drum from rotating out of gear.
You do not mention what year and model you have so I looked at the above file. I remember seeing that on my 85 400WRX when I had the clutch cover off
Jimspac,
Thanks for the information, I understand excactly the purpose of it now. However it just does not mount on my casing, which is an 81-82. The almost scary thing is that my old (broken) case did not have the mount for it either, they both use the 'regular' shiftdrum holder (the slim bracket that is connected to the shifter with a spring).
What I do not understand is how on earth I ended up with this part following dis-assembly of the old case...quite interesting...but really this is strange!
Well, I will just disregard this item for now and complete the engine build !
Thanks!
Lars
