In desperate need of electrical help
pcross71
Hoping you guys can help me diagnose (even fix) my 2008 TE 450. Just installed HDB front LED turn signals and powerlets and switches. Everything worked great for an hour or so but I think something shorted (perhaps when i flicked the blinker switch to test - note that they did work before). When I turn the key the front and rear lights light but there is not the usual sound (fuel pump?) and no neutral light (yep, its in neutral). Start button does nothing. I checked the two 20A (yellow) fuses on left side and three little fuses on right side and all appear fine.
I can't tell from the manual which fuse is for front indicators.
Thought? Help??
Would greatly appreciate any help!
It certainly sounds like a fuse. Do you have any lights on the dash?
The flasher relay is just past the fuses on the left. Trying to remember if people replace that when they go LED.
Sorry, not much help. Pretty sure the two 20A ones are for the Starter Connector, at least that's what it says in the manual.
I could concoct a great story of diagnosing and solving the problem , but am just going to "man up." Somehow I had bumped the kill switch to off! So, never mind.... In my defense, I never use the kill switch (use key instead), and have no idea how it happened.
I will say that the HDB LED front guards are great. And the powerlet's installed into the top clamp with switches from HDB are pretty cool.
So, my bike is happily put to bed on a charger and all is well in the world...
Thanks and sorry for the false alaem.
Heh... my first instinct was to suggest making sure the switch was set to run. Then I spent the time figuring which fuse it would be, and came here to post it. :lol:
FWIW, I believe it's the fuse with the yellow/red and yellow/black wires.
Regardless, glad to hear it was nothing.
