EricV
Hi gang. I'm looking to the collective and more experienced DS crowd to try and solve a riddle that's driving me nuts, and it also concerns me (as to my safety, and the health of the bike.) It's a TE 630 w/ 2K on it- just did a rear tire change, as well as going to a 14T CS. The new tire is a T63, which was balanced.
The issue is that upon riding it, and entering the first very low speed turn (neighborhood), I noticed a very distinct "squishiness" as I turned. It's fine in a straight line- solid, but as I would turn it would feel just like (if you can imagine what this would feel like) riding on a rear wheel with all spokes very slightly loose (enough to keep wheel feeling fine straight) and then when leaning over slightly like the wheel would "give." Very disconcerting. Almost like it's sliding ever so slightly, enough to feel it through the handlebars. Hard to describe, but I hope you get what I'm trying to describe. No squishiness in a straight line, nor when I apply rear brake, or accel. So here's what I've done...the obvious stuff:
Checked/re-checked the wheel alignment, by measuring each side from center of swingarm pivot bolt to center of axle.
Ensured that wheel is true- it is. Again, no odd behavior in straight line.
Ensured that rear sprocket is true.
Ensured that rear disc is true.
Chain tension is proper.
Spokes twang right all around- tension seems fine and again wheel is true.
When on stand wheel turns normally...no warbling or anything amiss. Grabbing it side to side/top to bottom for to and fro play (such as bearings) yields nothing unusual.
This is driving me nuts...can't figure it out. In 35 years of riding I've never experienced anything like it.
Now I can't help but think that perhaps, just perhaps, it's the T63. It's a very rounded tire (which on the tarmac means it'll heel over super easy when turning) and it has pretty tall knobs, which I guess could give and create this squishiness sensation. I sure don't recall this sensation on the new Karoo though, granting it's a different beast.
Sorry to go long folks. If there's something bone-headed I'm overlooking please chime in. Thanks!!
Eric
Eric
