subarumy98
HI All
Here are the symptoms:
Accelerate hard 1,2,3. Half-way through 3rd, the motor will die. You can throttle back, and she will pick up again and accelerate some more. Then I ran out of road.
Go to 3rd, and keep the throttle on half, accelerate gently, will pick up speed at a constant rate then suddenly accelerate harder as she goes lean, then die.
In both cases, as you throttle back, the sound is the boowang, banggg bangg boowang.
So here's what I'm thinking:
The fuel is not flowing fast enough. Somewhere between the tank breather and fuel tap.
Please check my logic and post your thoughts..
btw:
1983 500XC
45 pilot
430 main
std needle and jet
new needle & seat
everything is clean
2000m altitude
- If the fuel level was too low, then by accelerating slowly, you would not induce the condition, as the fuel will replenish fast enough.
- If the main was too small, it would not accelerate to top revs in 1st and 2nd.
- If the main was too large, it would not rev cleanly in 1st and 2nd.
btw:
1983 500XC
45 pilot
430 main
std needle and jet
new needle & seat
everything is clean
2000m altitude
