is anyone running the rr ECU/w11000 rpm redline?
Chevotaliveca
Ive got a 09 smr 510 with the powerup parts installed ,i have the husky special parts RR ecu on order just wondering if its a whole different map than stock (what id assume it would be )or just lets it rev past the factory 8900 rpm? thanks
the 2008 rr ecu is about half the size of the smr 2008(injection) ecu,... so i also don't think it will fit....
Huh well it's coming from a reputable dealer for my model so I hope it is right . Should be here next week . I'll update as it arrives .
Unless you have the pipes gutted or another exhaust system the ecu isnt going to work ,race ecu gives 1k more rpm and a different fuel map.
the ecu comes with the factory race pipe set up.
and while your at it install the k n air filter setup :thumbsup:
