Jumper
rappster
Is it ok to jumper the clutch wires to activate the starter on the TC 449 or does this send currant and drain the battery
You should be fine. The clutch safety switch is usually in series with the starter button, so there shouldn't be a current draw until you press the button. (keep it outta gear, though)
good luck.
