Kickstart hitting shifter? '77 CR250
Houredout401
Is shifter shaft/pedal supposed to hit kick starter on down kick? I have a loose shifter shaft (another bush issue no doubt) and noticed it seems to have been caused by the kicker, as the kicker hits/stop on the shifter shaft portion of shift pedal. Is this the way it works, or what is supposed to stop/contact the kicker on the down kick?
I have the newer dog-leg kicker on mime and it stops against the foot peg.
I held a standard L-shaped kicker against the mine to try and eyeball it and it looks like the kicker would clear the shifter shaft boss and stop against the peg also.
My '77 also has the newer dog-leg kicker,and it hits the peg just short of hitting the shift lever.
It looks like it would hit if the shifter was rotated too far down.
Hope this helps.
