Kind of ticked - Turn Tech
Wolf
I ordered my turn tech in December of last year. Didn't even pop it in until Late January and now it is dead. 6 months is not enough life out of this battery, and much to my surprise (NOT) they are out of business and there is no way to contact anyone. Not happy at all.
That's the plan, but....it still ticks me off...Joe seemed like a stand up guy and from what I have heard, he had no issues with honoring a warranty...of course once OOB that's all pretty worthless :(
I ordered the EarthEx from Zipty today for the 310. Will see how well that one works and then oredr one for the 250 as well.
On another note, Joe from Turn Tech e-mailed me today with a few suggestions on what to try with the battery to test it. He was on vacation, hence the lack of response....good on him.
Here are some tests he suggested to run (Copy and paste from the e-mail):
Here are somethings to check if you have a multimeter.
To check the battery.
First make sure the battery is charged (trickle charger at <2A)
1. Take a voltage reading of the battery. Record.
2. Press the kill switch, and then hit the start button for 4-5 seconds.
It may not run it for 4-5 seconds which is another sign that there is a problem with the battery. Running a headlight for 1 minute instead of the starter works if the starter will not turn.
3. Wait one minute and check the voltage.
If the voltage is above 12V (should be close to 13V) and moving up Probably OK, if below 11V then there is something wrong.
If the Trickle charger will not charge do the following then charge and run the test.
Charging the battery.
1. Connect a volt meter to the TurnTech battery (if you have one as this will make it easier to determine if it worked) 2.Connect the trickle charger to the TurnTech Battery.
3. Connect the positive and negative leads of the jumper cable to the positive and negative leads of the good 12V source (non-running car battery is fine) 4. On the other side only connect the Positive of the jumper cable to the positive of the TurnTech battery.
5. Then take the negative clamp that is left and touch the negative of the TurnTech battery, do this for approximately 1 second.
At this point the trickle charger should turn on, this can be verified on the volt meter. The voltage should be more than 10V and moving up quickly. Allow it to fully charge.
If the charger latches off when removing the negative lead of the jumper cable repeat step 5 up to 5 times If after 5 times the battery isn't charging still stop and send me an email. As there is probably an issue.
Once the battery has passed or failed the first test then run this test.
Checking the stator,
1. Check the voltage at rest.
2. Start the bike,
3. Check voltage at idle, this voltage should be higher than the rest
voltage within 20-30 seconds with the bike running..
4. Rev the bike while watching the voltage. It should rise and fall with
the RPM.
