I am thinking of swapping the brake pedal to the left after over 40 years of riding British bikes with the gear change on the right side,(right hand side). I think swapping the gear change brake lever was a cunning plan by .............. to damage the British bike industry. Not that it was not already destroying itselfRear brake actionned by left and right pedal ( and not or) !
I don't really see it either. Slam a downshift without the clutch when you think you are going to apply some rear brake and you will most likely see the reasoning. As for the rear brake on the left handlebar that doesn't seem to be a problem going to a normal clutch bike and gives the ability to dab with either foot at any instant while using the back brake. At least I could anticipate this possibility from seeing the trail ahead. For those of us who have the capability to put the auto engine in a more modern chasis with hydaulic rear brake either some fancy valving or adding another caliper would take this to the next level. There is nothing on that left handlebar on the auto anyway. Where or what sort of terrain would someone go to the trouble of making a left brake pedal but not go to the trouble of adding handguards like commonly called bark busters?
Unless you are an ex mountain bike rider that is likely to induce a certain amount of panic in some situationsthe better is to suppress completely the rear brake pedal and to have the rear brake to left on the handle bar
nothing to the foots![]()
Has anyone experimented that on his Automatic ?
Hi HuskyNoviceI have just purchased a 1977 360 Auto and the left hand lever (clutch lever) actuates the rear brake. The rear brake rod is modified about halfway along and it appears to be a genuine Husqvarna part. When the left hand lever is pulled in, the brake is operated by a long cable going to a point half way along the rear brake rod. This actually forces the rear brake foot lever up so you have to be careful to keep your foot off it while you hand brake. Is this a genuine part? (Offered by Husqvarna) It all looks genuine as far as I can tell but have never seen any pictures of bikes with this modification.
