Lighting For A 09 Tc450?
boerbebeop
Good day to all you highly intellectuals
What does a fella need to put a front light (s) onto a 09 TC450. It seems that the wiring harness has extra plugs on for something to add. Assistance would be highly appreciated.
Hi there
I've been wondering what the spare plugs are for as well?
Have you found out?
Cheers
Rad
You can install a small head light(candle), you will need only a voltage regulator, you will have to take the gas tank off look for rectangular plug with 4 wires on the back bone, I own a TC510 2008 and did install a trail tech X2 halogen but for this you will need to upgrade your stator check with http://www.motosportz.com/HVA-SS/HVA-SS-Trailtech.htm they sell a kit for your bike if you want to go that route cheer.
How about the 10 TXC 450, does it have the high output stator? It also has two extra plugs, one from the stator gets power when running, 3 prong, and the other has battery power, 2 prong. I guess I could just check the output, but if someone already knows?
