Lights on a 2010 TC250?
water racer
Just wandering what it would take to power headlight/taillight on a 2010 TC250?
TE stator?
Before you suggest I should have bought a TXC/ TE, I am into the light weight and simplicity of the TC.
thanks, GP
So I have found the mysterious 2 wire connector and it appears to put out 18+ volts AC at idle. Trail Tech makes a AC regulator that will hold voltage at 13.8 AC.
Will any headlight work on AC, or does it take a special bulb? they also make a regulator/rectifier that converts to DC just not sure if I need that and I was a little confused that I may then need a DC stator.
What do you think?
GP
