Lock wiring zipty breather tank
DErZ
Can anyone advise the best way to lock wire this bit. I'm not sure what the little piece of metal is for? Is there enough meat on the outer edges?
Hi, I don't know what Lock Wiring is but that 90 degree bend looks like the attachment that came with my Zipty Breather to connect onto a step down threaded adapter that screwed one end into the oil drain plug and the other onto the attachment that you're holding . The oil cooler then had a hose that ran to the oil drain plug via the attachment that you're holding.
I don't know if that makes any sense?
I think the pin retains the nut in position on the elbow. You can drill a hole in a similar location for lock wire if you wish, just keep it small. I've ran this kit without lock wire on this nut, on my 511 all year with no loosening issues.
