Looking for shock step bushings for upper mount
firecrackerkid
I've spent a couple hours looking on various husky sites and ebay with no luck. Anyone know where to find these or have an extra stash? Number 59 is what I am looking for. Individual part number is not listed. I need at least 3, as I have one.
Thanks,
Geary
Hmm, any interest if I see about having some made? These would be for upper mount on remote or piggyback shocks in an older frame where the heim joint rests on the bushing and not the stub welded to the frame ie up through 82 if I am correct. My only problem is initial tool up is $150 whether I get 4 or 40. I never came close to breaking even on the 40 mm fork preload spacers so I'm not sure if I will do these yet or not.
Yes, got loads of these in stainless. They are 20 - 15 - 12 and a 8.10 bore designed to use the fat O ring that the ITC Ohlins shock uses too. They are listed on the site...type: 'Husqvarna Ohlins Conversion Bush 8mm' into the search function...
Andy
Thanks guys!
Andy, I will get a parts list together soon so I can meet the overseas minimum. For now I will try John's trick so I can go riding :)
