Magneto questions
Dave Mills
My 85 500xc has a SEM ignition. My question is, what do the magnets on the smaller diameter in the magneto do, as opposed to the larger diameter magnets? I looks like there is one pickup fir the smaller diameter and multiple pickups on the larger area. Is one set for lighting coils? I am not planning on running lights, and would like to lighten it up
Bigger dia is generator/lighting and smaller is ignition.
Don't chop it up as a good one is hard to find.
I have/had a feeling those had the motoplat mini 6. Upon reviewing the 81-88 teck data sheet I downloaded from here it would appear only the four stroke models got a sem for 1985. Does it have two yellow wires? If so most likely it like the 87-88 250 ones with two 70 watt output. I kind of thought that one was less reliable than the motoplat mini 6. Might be kind of a shame to cut it up. I don't know what is going on with those four stroke advance timing specs. It also appears the cr modeks don't have a lighting coil.
There is drilling evident to indicate the rotor has been ballanced isn't there?
Whether with a 10 pound flywheel and a one pound piston even going to an internal rotor would really matter is up for discussion in my opinion.
Put loctite on the little bolts that hold stuff to that right case in that area, they have a habbit of coming loose.
magnets were cracked on the outside. also had itermitant spark , now no spark
the good news is the ignitions on the 250 400 and 500 are interchangeable for that year, expect to pay 75 to 100 for a good Motoplat mini-6 in those years
also MBZ makes a replacement new one you pay a little more but get more spark, downside no lighting coil, they are internal rotor like the CR type, had one gave it to my brother for his 87 430XC, nice upgrade but not cheap
