Magura master cylinder seals kit U.K ?
bonesXU1
I am having difficulty's finding a U.K supplier for a seal kit for a Magura 9.5 clutch master cylinder and was wondering if anyone can point me in the right direction?
Has anyone else had problems with there master cylinder leaking?
TE450 2010
Yes, and a seal kit will not fix it, I put 2 kits on mine and it turns out that there are casting flaws in the bore that leak just a tiny bit of fluid, just enough to make it messy. I check and replenish my fluid every ride now, takes about 5 minutes.
The flaws in my bore are gouges, they would have to be filled with something and them honed out. If they were just bumps. I would have honed them down long ago.
I would presume it is a common fault since I have been reading on the net a few people have had problems also.
I had a word on my Husky local supermoto raceteam guy and said he had found in the past it was difficult if not impossible to get any info or help from Magura in the U.K . He said he would just get a new one off the shelf and fit that rather than try chasing Magura about seal kits.
