Making a Husky stop. Any ideas on brakes?
flyarmy
The front brake on my 82 husky is very weak and I like a strong front brake. I have heard the name Woody passed around and read he can re-line hubs? Does anyone have more information on this process and where is Woody located? Maybe a DLS brake and hub is the ultimate answer? Any information on making the front brake stronger would be appreciated. Thanks. Mike
Mike- I also had heard his name over the years and finally broke down & sent my wheels to him (remove tires, tubes, rim lock & rim strips). What he sent back (almost 4 weeks) was nothing short of a miracle. He busts the wheel set down, puts in a new liner, arcs brake shoes, reassembles & trues. By far & away the best money spent (he's not cheap at all) however you should also learn to set up the DLS system- it takes some fiddling but once it's done MAN it freakin stops.
Woody is listed in the vintage parts sources thread. I have spoken several times with him... great guy.
T
I have used Woody to build a wheel, tru-arc shoes, and reline Husky drums. He is a miracle worker! Very impressive. David
Backing plates also require a bushing for the brake cam shaft as play builds up over time and weakens brake performance
