Maybe this will help with battery issues...?
DougW
I have a 2011 te310 and once before I had an issue like this but over the weekend it became a bigger issue. It seems the battery has been bouncing around in its holder and finally the positive batrery wire broke at the terminal lug at the battery connection. This of course left the bike seat in the desert till I temporally fixed the lead.
What it did the first time was bounce around and shorted to the frame and while riding the bike started to sputter as it cut in and out. I had put a longer heat shrink sleave over the wire but it I guess was moving around enough to finally break.
So hopefully this will give others something to check.
Doug
I used from velcro behind the battery to keep it in place and also used some cardboard on top of the battery so the seat smashed down the battery allowing no movement.
Make a slit on both sides of the little plastic fins that are there to hold the battery in place. Big enough to run a zip tie through it. Then zip tie it down. Other wise the battery can bounce around like it did on you and do far more damage than it has. Like destroy an air filter while riding or the battery itself.
