Measuring 4 Speed Cases
jaxpc
Where on a set of empty 4 speed Husky cases do you measure to determine the size. 250, 360, 400? And what are the measurements for the three sizes? Thanks
I think you should ask John LeFevre at vintage Husky. To be sure of a correct answer you'll want a source that has a lot of experience dealing with the 4-spd era. Unless someone out there is motivated enough to check their personal parts inventory for you. I would think that case measurements for different displacements would correspond to the diameter of the cylinder sleeve bay or the diameter of the crankcase. So, in other words I don't know the answer.
