Measuring piston/cyl clearance....your method ???
NFA1934
Hi All,
New fella here. I've recently acquired a rather nice old WR450 from a chum not able to finish the restoration that I was helping him with.
I'd like to know what method of measurement is most preferred amongst those that rebuild/refurb the old 2T Huskys. Personally,I've always measured the cylinder at the top and bottom (in line with the intake/exhaust ports),
then measured only the bottom of the piston to determine the existing clearance between the two components.
Now,the old factory Husky manuals disregard the above procedure in favor of measuring only the top of the cylinder bore(where the ring has not contacted),then measuring once again just below that point (where the ring has ridden)
and subtracting the latter from the former to determine clearance.
There's another method I'm aware of that involves simply using(plastic) shim stock between the piston and cylinder
with the piston setting at BDC in the bore (shim material is placed between the piston crown and cyl wall.
No doubt,there's likely a few other versions of the last method....but you get the idea.
So,guys,tell me how you measure,and if you use any of the above procedures......
Thanks,
The barrel you make a bottom and top jig (which fits over sleeve top) for with studs and torque to spec as when barrel to bottom end and cylinder head. Then you measure front to back, side to side, at the top, also below ring cut, at botttom and twice between bottom and top. Now you will have a picture with quite a variety of values which will show how oval and barrel shaped the sleeve wears out.
Of the above measurements you take the largest and then determine piston oversize so that you can get a clear cut all the way through the metal of the sleeve when boring.
With this method i have seen bores so worn out that i had to go one oversize extra.
You measure purchased piston front to back about 5mm from bottom of skirt.
Then you properly bore and hone to tolerance with barrel and sleeve torqued in jig.
After this jig is released and you can measure again and see how much the sleeve actually distorts when released from torque spec. Dont worry about these measurements, its for interest sake and the sleeve will be fine and close to perfect as possible, with real ringseal and constant gap all the way up and down, when torqued up in engine.
The plastic guage is a waste of time and will never give a clear picture of actual barrel shape and tolerances.
