gavcan01
Ok. Not sure if I should even post this but I think it will be good for me as part of the cleansing process. I'm a bit pedantic when it comes to servicing my bikes and its important to make sure everything is within tolerance and torqued up to spec for the riders upmost safety, although it would seem.
Below is the result of "rushing" your supermoto conversion on your TE449 to blap around the streets after work. After changing the front wheel and thinking "I'll come back to that after the changing the rear" some nameless idiot (me) forgot to torque up the calliper adapter bolts.
Bottom bolt came loose first and the calliper adapter wedged in the rotor causing front wheel to lock up causing a bit of catapult action. Lucky enough to walk away with no skin off and the most part so did the bike. Only a nasty scratch on the fork tube which needs replacing and a bent subframe which is bent back.
So please answer me this. Is there anyone else out there who may have had a bit of a monumental f up due to rushing or just plain numnutism.
