metal flakes in oil
gopie
I was doing an oil change on my smr449 yesterday and when i opened up the screen filter closest to the oil drain point i found a heap of what seemed to be metal flakes (didnt have a magnet so couldnt check) in the oil and on the filter. There wasnt any in the other screen filter or main oil filter compartments though. My bikes got just under 14000kms on it (nearly all commuting with the occasional hills ride) and seems to be riding fine. Can anyone shed some light on this? Im hoping its not to serious!
How much are we talking here? A tablespoon full of metal, or a couple shiny bits in a bit of oil? Probably not a big deal. Listen for new sounds on your next rides, if everything sounds fine forget about it.
I noticed something similar on the cylindrical screen filter of my 310R on its first oil change. Had about 2 relatively easy hours on the clock at the time.
As a cheap and easy way to help monitor what's going on internally in my motors I drain my oil through those disposable strainer funnels that painters use (www.amazon.com/Professional-Full-Flow-Disposable-Strainer-Funnels/dp/B00A3EK25Q).
Since my 310R's first oil change I haven't found anything except for a bit of "fuzz" on the drain plug's magnet.
As danny318 mentioned, it's probably nothing serious but if were my bike and there was lots of the stuff I'd take it easy and perform another oil change PDQ.
If more crap comes out I'd start looking for the source of problem preemptively rather than riding around wondering when the big seize might occur. Good luck.
Maybe run some cheap oil in it for a few miles then drain again. If something's coming apart, you'll have more metal.
Then again, any oil is cheaper than a major rebuild.
Thanks for the reply guys. I also had the bit of 'fuzz' in the oil during my first oil change but theres been pretty much nothing since then. Unfortunately i didnt take any pics but there was quite a bit of metal (im still assuming it was actually metal) in very fine granules, just big enough to differentiate individual flakes. I guess around the size of sand granules (maybe a little bigger). I thought it was a bit weird that it was only located in the one screen filter though. Im going to do an oil change again as soon as possible to see if theres more. Unfortunately i cant stop riding the bike as its my only transport! Ill post an update after dropping the oil again.
As I'm sure you know get the oil up to operating temp immediately before draining.
I've found quite a bit of additional oil will drain out if, after removing the small skinny filter screen, I free up the rubber oil line that connects to the barbed fitting and extend it straight down towards my drain pan.
With the magnetic drain plug and barbed fitting still removed I then put the the bike in 3rd and using the clutch make a couple easy, half-hearted attempts to push start it. Obviously the goal's not fire up the bike but merely turn the motor over a few times which make it spit and dribble the last bits of oil out.
Actually if you perform this procedures both ways on a slight incline quite a bit of oil wil come out so plan accordingly on how to capture or it (or hide your deed).
After performing the above and cleaning my Scott's filter I reconnect everything and refill the motor with exactly 30 ounces of Castrol Edge 0W-30 Syntec. Works perfect every time.
Changed oil today after the first real trail ride on my 310. It just received the full Zip Ty treatment and had 5.2 hours. Normal fuzz on the magnet and just a few discernible flakes on the lower screen. Stainless filter was clean. I expect nothing but fuzz next time, but the engine is still new. There may be a few more bits lurking in there somewhere.
Checked my mileage carefully after the ride and I got 54mpg! Trail riding is going to give me a range over100 miles! Much better than I expected.
Hi! Had a tc449 with the same issue on the two first brake-in oil change. My friend who was working for husky at the time told me it was normal in the brake-in period but after two or three oil changes I should only get some fuzz on the magnetized drain plug.
