mikuni to air box rubber/boot question
have a stupid question but any help appreciated. have a 1976 wr360 and in need of the carb to airbox rubber. they're available for order on the net, but wondering if i can sort a diy replacement for the time being. obviously the dilemma is that the rubber is two different sizes. thanks
johnnyandluther,
Some times you can get away with rubber pipe adapter, there made to match up two different size diameter pipes, there available
in many hardware & plumbing supply stores.
Just make sure you get good seal on both ends, or you'll suck dirt in & that can real expensive :banghead:.
Husky John
I kind of have this issue to, the airbox boot is dry rotting but it's not poking through yet, would wrapping it in electrical tape be an acceptable solution?
