milky oil from hole under water pump??
bensl
started my 2012 te310 up tonight only to find milky oil spilling out of the hole under the water pump. i searched through the manual but i couldn't find any reference to it. im guessing it means the oil seal on the water pump needs replacing?
can anyone confirm or suggest another cause.
thanks
ok, thanks. is it easy enough to replace? i have done some searching online but cant see too many references to this happening. one i found said that hole was a spark plug drain hole (older model) and another suggested the head gasket could be gone too.
