mounting modern tire on vintage bike...???
andy75wr400
I put a new tire on the 75 husky wr400 and the left side is rubbing. maybe i put spacers in wrong spot but doubt it. but how should i space this out? just center the tire between the swingarm and hope for the best? I had been measuring the threads in the adjustment....? is this wrong?
Need some help
If it was ok before, I guess you have fitted a tyre with a wider section.
What was fitted, and what have you just fitted ??
Don't space the wheel just because of the tyre. That will cock up the chain alignment. Maybe a spacer has gone on holiday on the workshop floor !
Like Grouty said make sure the chain is in line with the sprockets, or you'll have trouble.
Is there a pdf for clymer manual for 75 husky wr400 here on cafe husky? I want to make sure i have all the parts where the parts are supposed to be.
It's the last one on the list. Scroll down to the bottom. They all look the same for the rear wheel mounting though. Barr the 125 at the top.
