MT43 mounted...not the easiest tire I've done!
Biggziff
Taking the Michelin Enduro Competition or whatever it's called off the rear was a P I T A!!! Are those tires really that stiff? New Pirelli went on OK, but again...not the easiest tire I've done. I need to buy one of those tire changing stands so I'm not on my hands an knees anymore with 4X4s under the rim. :)
Anyway...new MT43 mounted and with the 13 tooth front it looks like I've got 3/4" between the mudflap and tire so I hope that's enough. We'll see tomorrow. Based on nearly every review I can find, these are *the* tire to run.
I've set it at 12 PSI to start (HD tubes) What do you guys like to run these at for dual sport (90% dirt)?
12 psi is too much. Let that tire work like it's supposed to and run 10psi or less, 8-9 with an HD tube should be ok.
Yes on 8lbs PSI and I use a trash can and wd-40 for helping the tire slip on around the rim. Works like a champ and dries so you have no worry of tire slipage.
I bought a gallon of tire bead lube for $5 which works a lot better than the windex I've always used. Live and learn.
I ran the tire at 10 PSI and it was fantastic. I see why they call them velcro tires. Even in the slimy mud it worked well and actually felt like it tracked a lot better than the knobby did in the same stuff.
I don't believe I'll run a knobby again.
