Ok long story short, new to me 06 te450. Was sold to me with a broken kick start return stop. PO had taken out the electric start. So I had never heard the bike run. The owner has been helping me, not like he sold it to me and said its your problem now.
I fixed everything, put it all back together. I was assured that if I fixed the starter problem that the bike was in good running order.
I was having lots of problems getting it started and idling once I fixed everything. I checked the throttle cable cam and it was partially opened, the idle screw was not even close to hitting it. I gave up for the day and talked to the PO and he said he might have stuffed some paper towels int he intake to make sure nothing go up in there.
oops!
Anyway, there was a chunk of paper towel in stuck in the slide of the carb.
My question is...
Some of the towel puffed out the exhaust, so it went through the cylinder. Is there any risk now that everything is cleared?
I have not had reinstalled everything, I wanted to get some advice before I went any further.
Thanks in advance,
Jay
oops!
My question is...
Thanks in advance,
Jay
I agree with Kelly, if you got the rest cleaned out and made sure it isn't going to eat any more things should be ok.
) and some no-name brands, I went with the Turn tech 5.0, works *really* well so far. I have hope it will last as long, or longer, than the original and is much lighter.
