Need help to Identify 87 XC430 fork valve kit
motomwo
I pulled apart a set of 87 XC430 40mm forks to inspect and install new seals as I want to use these on my 83 XC250. I found what looks to me like a high quality aftermarket dampening rod and valves assemblies. (See pics below) This looks to have replaced the complete guts in the forks and only reuses the oem fork tubes and spring that is cut down to 59CM. The spring sits on the gold steel ring that is located on the black tube. Can anyone tell me anything about the kit as to who made it and is it a good one? The upper black (hard anodized) tube looks to have a valve in it and a piston that slides up and down inside that tube. The bottom valve is simular to the oem valve but is different and the bottoming out cone looks shorter than the oem cone. Just like to know what I have before re-assembly. Thank you for the help.
Marty
what are those from?
don't recognize them at all
I pulled them out of a pair of 87 430 XC 40mm conventional forks. I know they are not the OE parts so trying to identify them. The pictures are showing only the dampening rod and valves from one tube. Hoping someone knows.
Marty
Yes that is correct but would like to know what company or manufacture made this dampening rod and valve kit this is out of the coventional 1987 40mm forks.
Marty
Marty
It appears to be similar to a Simons "anti-cav" fork kit but the dark colored tubes from the Simons kit were made from a PVC type material and yours appear to be made of metal. I do know Husky Products made an "anti-cav" kit but I have never seen one to know what they were made from.
The anti-cav was the fore runner to cartridge forks and back in the early to mid 1980's it was the "shiznit".
Thank you so very much for the info! I do appreciate it! I was beginning to think that I would never get a answer to my question. A couple of days ago I installed these 1987 forks and the kit onto my 83 250XC to give them a try. I modified the lower legs by removing the disk brake caliper mounts and filling in the machined area of the rear rib so they look just like the 83 forks. With this kit the forks have about 12.25" of travel a bit more than the oem 87 xc forks. I used 10 wt Belray oil to start with but may be to heavy, will see. It may be a while before I get to try them out as the weather here in north eastern Oregon has turned cold and wintery. If anyone has any more info such as possibly a catalogue or page or the Holy Grail, an instruction sheet for this kit please post it!! Thank you,
Marty
Marty let me know how this set up works . Ron
Hi Ron, I sure will. It may be a while before I can give it a good test as you probbably know the weather has turned cold over here in the Grande Ronde valley and the mountains have got a lot of snow already. I will probably take a trip over to the Baker City area, Virtues Flats when we get a warm spell.
Marty
bike looks great premo...wish mine still looked like that
thank you
new plastic and a good starting point go a long way, the pipe is an UpTite and works great too, I bought new forks and a new shock with a new spring for this assembly, pretty much went all out to make this at the time my daily ride, it is currently apart due to parts of a main bearing went through the bypass ports and took out pretty much everything up top, fortunately I have a bunch of spare engines laying around that I can slap in it, just having to much fun on the other bikes right now to worry about it, definitely this winter it will go back together, have one complete set of new plastics for it if it ever gets to looking a little dull, if you look hard you might notice it has a CR tank as it is a little thinner for riding in the trees, the shrouds give it away, it actually is a WR with an XC swingarm, a CR engine and a CR tank
i have a spare tank thats a cr and definitely noticed a slimmer profile...i usually run a xc/wr tank..i used to have it riding lower with a heavier, shorter, spring..i need to get a new one or powder coat mine...handled better, especially in the woods...im forced to run a lil too much sag right now..
Thanks for more info....I wish I can see the two tanks to better understand ....;).....
at the seat they are obviously the same but they get wide quick from there, adds at least a couple total inches at the front, my project tanks are stored or I would take a picture, the difference is 10L to 12L of fuel, where do you put 2 liters of fuel stylishly, if you look up the application obviously CR models but oddly all 240cc, WR400, European WR250 and 430 auto, who thinks this stuff up, my guess is in the US market they had the desert in mind for most of the line after CR
