jkm
2007 TE450.
At 3000 miles, I lost the clutch - while riding in snow.
Replaced stock slave piston with 7602 piston and seal. Problem solved.
At 4000 miles, I lost the clutch again. This time during a Fall Dual Sport ride. The master cylinder was empty. I was able to bleed it and get it to work well enough to finish that 2 day DS ride.
During and after that DS ride, when the bike was parked overnight or longer, there would be clutch until the cold bike was started. As soon as it started, the clutch would go away. As long as there was fluid in the master cyl, it would come back after pumping of lever few times. Over the next couple weeks, I checked the mc and it always had min oil in it. But, I bled the system a number of times during this time period, thinking my problem might still be air in the system. So, I was putting m oil in the system, and that made it was hard to tell if it was going down or not. I could ride the bike as far as I wanted once the clutch came back after the cold start up, and it would not go away.... until the bike sat overnight again.
I could not find any leaks.....but I
Rebuilt the master cylinder anyway. Rode the bike 50-100 miles or so and the clutch worked fine.... until the bike sat overnight. Cold start up, lose clutch. Pull lever a few times, clutch came back. Ride all day, no problem.
Looking the bike over for outward leaks, I was pretty sure that I could see some sort of 'film' on the inside of the sight glass. I imagined this to be mineral oil which was not mixing with the motor oil.
I'd read stories of the slave cylinder being 'out of round', so.....
I ordered and installed a slave cylinder from Zip-Ty.
When re-installing the 7602 piston and seal, the system lost fluid. But, along with the new slave cylinder, Zip-Ty had sent an extra seal for the stock piston, so the stock piston and new seal were used. The leak stopped.
Rode 50 miles in the snow. The clutch worked fine. After the ride, the Bike sat in an un-heated garage for a week. Walking past the bike, I reached out and gave the clutch lever a pull and there was no clutch! Looked at MC and it was about 1/3 full of Min oil. I'd lost m oil again. I filled it about 1/2 full and rode the bike. The clutch doesn't feel right, but I'm guessing it was actually too low and needs bled.
I had a machinist mic all the parts. Stock slave cylinder is a bit out of round in one area by 1/1000". 7602 piston is not out. The seal on the 7602 piston was well worn (Thanks to Clay for sending me another!)
I'm at a loss. I have not replaced the clutch line because I can't find any outside leaks and I'm still sure that I was seeing mineral oil on the inside of the sight glass.
But with all the new parts, I'm still losing the clutch. Anyone got anything? Thanks.....jkm
