pahusky
It’s kind of been on the back burner, but I figured now is a good time to finish it up and get it sold. Should make someone a good trail bike… Bike is a 2013 TXC250R.
When I first got it back I pieced it together enough to see if it would run; started on 6th kick. Let it idle about 10 seconds and shut it off. Checked the valve clearance changed the oil, or should I say tar…
http://www.cafehusky.com/threads/bike-recovered-whats-left-that-is.51886/
I had the stock handlebars, stock exhaust, found a decent rear sub-frame, decent used tires, stock tubes, new rear fender and a couple of other bolt-on pieces I could replace. Pulled the WER reworked suspension and had it gone thru for use on the 2012 TXC250 we have also and put the ’12 suspension over on the ’13. I also fabbed up a sub-frame mounting bracket that was ripped off the frame.
Before welding the bracket on I unplugged everything I could and thought I took everything off I needed as a safety precaution. And right up front; I hate electrical problems; but now I have no spark! When I spin the engine the red ‘Dash’ light comes on and when I pulled the tank there was pressure when I did the elbow disconnect.
I had the chance to try a plug coil from a donor bike, but still no spark. I seemed to have no output from the stator…so, I found a parting out ’13 TE310, which has the same electronics and picked up the stator, rectifier and a kick starter that was missing. Bolted on the stator, nothing… bolted on rectifier, nothing… Went thru the usual - fuses, kill switch, disconnected, cleaned and reconnected all plugs I could find.
So… Any procedures I need to know more about that I may not be doing or am doing wrong? Is it possible that I may have ECU issues?
I’d rather change a hundred tires than deal with electrical issues!!! Anyway, any guidance would be greatly appreciated…
