Neutral Position Sensor Switch on 12 TXC 310
need2boat
Can anyone tell me what the NPS switch does on the TXC bikes. The wires on mine is in bad shape and I've just been taping it up.
The TXC doesn't have a neutral light or indicator so I wasn't sure of the purpose.
Maybe I should rephrase. . . I'm waiting on a replacement for mine. The wire is cut so close to the plastic sensor I can't repair.
Does the bike need it to run?
It's used to determine what gear the bike is in to adjust the mikuni fuel injection depending on what gear you are in.
The keihin fuel injection systems a year later do not use this feature and are just plugged with a blank plate and no sensor.
