Just got an 08 510 smr. Only has 75 miles on it. Have a few questions for you seasoned Husky riders. First off, this is my first motard or dirt bike for that matter.
1. I did the fuel pump mod and the orange wire was broken off. I couldn't really see where it broke off from but I noticed some solder on what I'm guessing was a sensor so I soldered it to the soldered area. Is this correct? I also stripped one of the screws a little holding the fuel pump on but used loctite so hopefully it won't leak.
2. There is some bluish green oil coming out of the airbox. Is this just air filter oil or is there a possibility that I am getting coolant in the motor oil and it is coming out of a vent or something? Is it really likely that the coolant would get into the oil in only 75 miles?
3. The air filter oil has stopped coming out of the airbox but noticed a spot of greenish oil at the bottom of the frame. So now I'm getting nervous. Will clarify on this later when I realize where it is coming from. So this isn't actually a question.
4. Could someone post a close up picture of the left side of there engine. The previous dealer did a little work to the bike and I want to see if they routed the wiring properly. Seems a bit messy.
5. What does this wire do? It is touching the engine and getting melted through.
6. I was checking the coolant and there is no coolant in the reservoir by the shock but the radiator is full. Should I fill it up or leave it because the radiator is full.
7. I keep reading about one finger braking on these things, but I feel as though you have to squeeze the brake much harder than you do on a sportbike. I had a Duc 1098 caliper put on this because the other was screwed up during shipping. Do you think they messed something up or do you have to squeeze it much harder than a sportbike? Is it because of the longer suspension travel?
