New Injector
ozzie
I would like to know where is the best place to buy a new injector for a 2008 TE 450. I dont mind if its another brand or so on just as long as iit keep on going
Cheers Kel
You definitely need an injector? I only ask as i haven't seen too many fail in comparison to things like fuel pumps and relays/wiring
I have put a new fuel pump and I think I have clean the injector. I rode it after I clean it yesterday took it for a spin and it was all good even at full noise, but today I rode it and when you ease on the throttle there's no back fire, but when you give the juice it starts to backfire or when you 120Ks it will do it as well. A new injector will be part of the elimination process
Cheers Kel
Put the kawa 12 hole injector in. Flows the same but better spray pattern. I put it in my '10 and didn't made a difference in the fueling but ran better. (checked on both autotune and dyno)
I can look up the part number if you want, must have it somewhere.
From memory was cheaper too.
Try running some injector cleaner through it-double or tripple the dosage it will not hurt.
If you could give a part number or a link that would be great
I got one and the part number was 49033-0011 for the 12 hole injector (Canada)
There was a reason I used the 0010 injector, I did some research then and I believe the result was the flow of the 0010 was more compatible or better than the 0011.
