New Thread required...
suprize
Ive stripped the lower bolt holding the clutch cover on and drip drip drip...
any suggestions for a semi safe fix? ive thought i might lash the gasket with goo (a loctite or silastic)
i could fill the offending thread with a supa metal and retap or i could helicoil..
Im thinking heli coil for a more permanant fix but i havent time to rip the thing apart and im not sure i can get a straight run at the thread with the motor in the frame.
so any temp solutions will be appreciated from the collective mr fixit's
any ideas???
Cheers
A 'Wire thread insert' (Helicoil) is the best way. Seek out an engineering business or buy a kit. M6x1.0 pitch x 2D is what you need to look for. The 2D is 2 x the thread diameter in length (of insert). You could ask for 3D, but they are more difficult to find. So 2D gives you 12m/m of new thread length.
Hope this helps!
Andy Elliott
Hope this helps!
Andy Elliott
Yes, do that
As Andy says .... Helicoil it. You will only regret it later if you bodge it now. If you have to remove the motor to do it, then that is what is required. Not a long job to pull it anyway.
Lay her on her side so she does not leak, clean with degreaser and add silicone. Allow it to cure and away you go. Why mend it properly when you can bodge!
yeah you can get a 3 pack at the hard ware store for ten bucks .
mate has one on the manifold flange on his land rover . think hes up to #4 now ...
Sh$t how many solutions to a problem can there be!. i will go the Helicoil i think purely on a do it once/right basis that i have never followed before!
