New to the 12 TXC310....efi mapping question.
flatout111
What do you need to map the efi? I would like to make it a less racy bike and more of a technical, endure bike better at slower speeds. What is needed?
I admit, I am a newb to a lot of this so please understand that I do not know a lot of technical, mechanical stuff.
Thanks.
You can try the map switch, but I don't think that is going to get you what you want. You can tune the ecu with either ibeat or HST (or JD/PCV add ons), but leaning out that engine is a really bad idea (which is what the switch does too). Cory was a monster on these bikes. The way I would do it is through head porting and lower gearing. Our head porting builds serious torque right from the bottom and lower gearing, lets you do it slower.
They run okay leaned a little as long as you are not a AA rider with it pinned all day.
if you trail ride it you can lean it with I-beat and stick a SA or DB killer in the pipe and calm it down and make it quiet too. Gas mileage goes way up that way too.
The TE250 with a 4 pt injector is a little smoother and less snappy than a 2012 310 which is kinda barky off idle with an open pipe.
