No power from battery to starter_2012 TXC310
Taylor4ek
My TXC310 suddenly decided to stop starting. With a fresh battery it won't deliver power to the fuel pump or the starter - nothing happens. I tried bump starting it down a hill and kick starting it and still nothing. Is it possible to kick start this bike without a battery? Are there fuses or any other inexpensive possibility at fault here? I'm fearful of a complex wiring problem. Thank you.
There is a fuses and a relay. The bladed fuse you can wiggle out and look at to see if it's blown. you will see a melted line in the middle if you have a new one you'd see the difference. You can also use a volt meet to see if power is on both sides of the wire going to and from the fusee.
