So yesterday I worked late on the my new (to me!) 2011 TE310 to get ready for my first ride with it today.
The bike came with a large capacity tank installed on it which I really don't care for (too big, too heavy, don't need that much capacity and the plastics and seat don't fit correctly when it's installed). So during the week I spent the evening fitting the standard tank on the bike (what a pain!) and yesterday evening while giving the bike a once over I realized that the tank was leaking!!!![Mad :mad: :mad:](/smilies/mad.gif)
Not much, just a trickle at the back of the tank. I took it out (did I mention it was a pain****************************************) and realized that one one the thread insert that is used for the bumper at the rear of the tank had been repaired and apparently not very well causing the leak! ![thumbsdown :thumbsdown: :thumbsdown:](/smilies/thumbsdown.gif)
So, big tank goes back on... have to transfer the fuel pump, etc... put it back on... fill with fuel... ignition on... put the start button.... no go! Starter turns over but bike doesn't fire
. I peek inside the tank and see that the hose connecting to the pump to the fuel filter had popped out. ![banghead :banghead: :banghead:](/smilies/banghead.gif)
Drain the tank, take it off (did I mention it was a pain?), pull the fuel pump out... fix the hose connection, put it all back together... put the tank back on the bike, put just enough fuel in it to cover the fuel pump... stab the start button... success!!!![banana :banana: :banana:](/smilies/banana.gif)
By now it's pretty late in the night, so I head out to bed.
This morning after a few hours of sleep I load the bike and my gear and head off to the riding area.
Unload the bike, start it up... works fine. Let it idle to warm up and start to get my gear out of the truck... bike dies.![Confused :confused: :confused:](/smilies/confused.gif)
From there it went downhill... When I tried to restart it, it fired up for 1/2 second and died. Giving it a little throttle... didn't help. Tried for a while, drained the battery... time to go home!![censored :censored: :censored:](/smilies/censored.gif)
So now I am back to trying to diagnose what's going on. Back to basics, I have to check it there is gas, air and spark.
For the gas part, when I turn the ignition on, the fuel pump starts whining, so I assume that this part works. I have drained the tank and taken it off the bike. The question is how do I test that the right amount of fuel pressure comes out of the tank? How much should it be? I assume more than a trickle (otherwise why put a fuel pump?). How does one test for it?
Also, I looked at the 2011 TE310 parts diagrams on www.italhusky.com and could not find the fuel pump / filter assembly anywhere (all the crap that's inside the tank). Any pointers would be much appreciated.
Thanks.
Denis
![cry :cry: :cry:](/smilies/cry.gif)
Thanks.
Denis
