OEM TE310 Header flow clean up (FYI detail effort)
robertaccio
I forgot if I posted this all ready.
I had my header off my 2011 TE310 and during inspection noted that inside the pipe the weld from the flange to the pipe had a fairly large weld slag line around it.
So I broke out the grinder/porting tool and smoothed the transition to perfectly smooth (there is plenty of weld structure line around the outside of the pipe) The weld penetration was spot on and there are no voids, just smooth metal from the flange into the pipe.
Just a small little dial in move, a time to kill, details effort. FYI
The dyno showed a .002 % increase in HP and less engine vibes (just kidding)
