Off Idle Stall
MGW
I finally had my 2011 TXC 250 out on the weekend. It was great other than once it was hot, it would often stall when I gave it some throttle from idle. I'm guessing this is a fuel injection issue? Is there any fix for this?
It wasn't particularly hot, the fan on the rad never came on, but I would say normal operating temp.
My '10 TXC250 does it too. The JD tuner and bumping the idle up helped, but didn't eliminate it.
You should adjust with I-beat and add an iridium plug.
Your bike should take throttle off idle with no problem.
Check TPS setting with I-beat.
My 2010 TE250 with a 4 pt injector never stalls, while my 12 TXC310 with 12 pt injector sometimes flames out when riding hard.
It is supposed to be the other way around.
