Oh no Ive killed it: TE 449
dale ogden
hi i was having a bit of trouble with mt 449 running poor and i posted on the forum and i got lots of help thanks ,so striped the small tank out to check the pump filter it seemed fine so i put it all back together but now it wont start it tuns over but wont start i looked at the fuel pipe to injector i disconnected it and pushed the starter and fuel came out so i think the pump is ok, any ideas help thanks
Pull the plug and see if its wet or no. Also try tapping on the starting relays with a wrench. Sounds stupid but ive had recent problems with intermittent relays. Right side by the radiator and cyl, head.
ok thanks guys i will have a look at the plug and re check my tank job ive prob dun something wrong not the best with the spanner lol , thanks hope i can sort it out love the bike when its running
ok ive had a look at the spark plug and it sparks sometimes and sometimes it doesn't the 3 wires that go into the plug cap dont look very good i can see the copper wire on the black wire just were it goes into the connector followed the wires back but they seem to go into the main loom how do i replace the 3 wires and connector thanks:confused:
You may need to visit an auto elec & have them repair the plug pins for you.
Probably be the easiest solution & shouldn't be very dear.
The connectors used on the bike are common on Jap cars (Yazaki brand) so they should have pins....
