Oh sheit!! now what
RickyDZero
Last summer a friend of mine was helping me change oil on my TC 250 and he over tightened the screws that holds the oil filter and they stripped out. So I had them helicoiled. I noticed they were getting looser and looser after each oil change I did, well today they stripped again and now it leaks oil. Help ! what do I do now?
If the bolt or female threads stripped (I'm thinking not likely) use a new bolt or put a new helicoil in. If the helicoil stripped out of the case, MIG weld, drill/bore, re-thread/tap. watch the mating surfaces.
you might be able to get a time-sert in there if there's enough meat left- but you're gonna hafta get it below the mating surface (which is usually not a problem).
and re-calibrate your wrist maybe? I use a 8mm nut driver to insert these bolts and 80% of the other fasteners on my bike (I frikken hate T-wrenches BTW) because it makes it harder- but not impossible, for me to over-torque 'em (torque reqs on the oil filter cover are pretty light: 5.5Nm or 4ft/lbs... call it 48inch/pounds).
good luck.
Thanks for the help Trenchcoat. I have seen what they call a keensert which sounds like what you are writing about with the time-sert, but like you said is there enough meat to do such a thing? By the time you drill and tap the key-sert, it looks like it will be pretty thin.
yep you're right. But the time-sert is pretty thin-walled compared to a heli-coil or keen-sert. look it up for your 6mm 5mm? bolt; you might have a chance. Time-Sert
You may end up having to do the weld & re-drill thang. As noted on another thread, if the welder or machinist does it engine-in-the-bike, remove your ECU and maybe your regulator beforehand.
Hey guys, problem solved. The stripped bolt was not helicoiled like I payed for,:banghead: now it is and holds great. Still leaks a little,but the O-ring is flat. So I ordered a new one from bills. (Be here fri or Sat)
